Replica 964 RS...Anyone build it?
#31
Originally Posted by madmoog
I suppose you could actually start a new thread "Do you (actually) want an RS?"... or is it what you think you want, have been told you want etc. Not to decry any RS, but often the funds aren't there and the difference between an RS and C2 can do a lot of good (ignoring the RS investment - another issue).
Mine started as a C2, but as a 3.8, striped, big reds and suspension etc. goes (and stops) very well. It could be lighter and more focused (as Thomas's is- may happen yet), but I now realise (old age and my limitations) that the last couple of seconds aren't something I'll be pushing for, but a/c and leccy windows are nice!!!!
Horses for courses I suppose but whilst a modded C2 (or C4 for that matter) may not have the history or provinence, it could be a good, or even better all round package.
#32
Originally Posted by Bill Verburg
Truer words were never spoken, Being an old guy, I kept AC, PS and P/W
#33
This latest input to our thread now begs the question: Is a stripped down RS America (maybe even not so stripped down) the perfect platform to build a great Replica from? Many of the RSA's for sale have had the suspension, clutch/flywheel, roll cage, seats, etc. work already done. Heck the brakes, LSD, Lt Wt interior, door panels etc, and manual rack come standard. For somewhere in the $40K range plus specific add ons to suit your taste, like RSR camber plate, tie rods, etc. say $10-$15K , you might have the perfect package that retains it's value, by virtue of it being an RSA to begin with. $55K all in is not a bad deal for a fantastic car that can be driven anywhere.
Thoughts???
Thoughts???
#34
Thoughts???
Thoughts???
#36
Location: WhippetWorld, .........is it really only this many
1 Post
There are lots of valid reasons for puirchasing and owning an RS lightweight, N/GTclubsport, or cup car but none of these reasons really apply to the recreation of a replica.
If you want the best 964 track/race car you're as well to start with a standard 964 shell. Geofferys race car project on this forum is a near perfect example of how to build such a track car.
Similarly if you want all the comforts of a road car but a little extra ability on track a mildly modified C2 will give 95% of the RS experience on track with far better road manners.
The 964RS was a well judged package in it's time but things have moved on and there are better parts available both from Porsche and reputable aftermarket suppliers than those fitted to the factory cars and there are many proven upgrades that have found their way onto the RS variants as well.. I think it ought to be remebered the RS was simply a factory modified 964.
My C2 is if anything more extensively modified for the track than Thomas C2. A number of the options on the 9M recreations debuted on my C2 and I can't help wondering how much their work on this car influenced the idea in the first place.
My recipe for a C2,
suspension
Cargraphic clubsport (H+R Supercups) coilovers with uniball top mounts
964 RS sway bars
993RS front hubs
993RS front wishbones
brakes
993tt front clipers and discs
965 rear caliper 964RS rear disc
993tt hydraulic brake servo and ABS
pagid RS19 pads
steering
kept the power steering (RS manual rack is too much like hard work for me)
993RS tie rods
engine
AMD MAF and chip ( Porsche moved over to using MAF on it's later cars)
custom exhaust ( saves 15kg from the cat backwards, the standard exhaust isn't very RS in weight terms)
cat bypass
open airbox cover
RS single pulley fan conversion
RS engine mounts
gearbox
993 RS G50/32 supercup 6spd
RS flywheel and clutch
RS tranny mounts
interior
recaro spg seats
safety devices full cage
Sabelt 6 pt harnesss
lightweight carpets
delete sound proofing
no radio
no door panels
body
carbon fiber front hood, rear deck lid, RSA rear wing, doors ( the retention of the electric spoiler on the RS models is perverse - it's very heavy)
manual windows
manual mirrors
6kg battery
RS type working front airducts
delete rear wiper
delete large washer bottle
wheels
18insGT1 Veloce ( 32kg a set)
235/265 Dunlop DO2Gs
current weight about 1170kg
to come soon
engine rebuild probably to "Christer" spec
delete sunroof
carbon fiber front wings
things I wish I'd done
strip shell and weld in full cage
My recipe for a C2,
suspension
964 RS sway bars
993RS front hubs
brakes
pagid RS19 pads
steering
993RS tie rods
engine
cat bypass
open airbox cover
RS engine mounts
gearbox
RS tranny mounts
interior
recaro spg seats
lightweight carpets
no radio
no door panels
body
manual windows
manual mirrors
6kg battery
delete rear wiper
wheels
to come soon
delete sunroof
#37
Thanks for your info Tony,
Sounds like the "stuff"!!! How do you plan to handle the sunroof delete piece. I have been thinking about what is entailed with this effort.
Cheers
Cheers
#38
Tony,
Can you tell me more about this?
I have already done a complete top end rebuild with LWT flywheel and chutch
along with the cat bypass, primary bypass and open airbox cover with and "RS type " chip
But I think I need a new MAF sensor, and you tell me more about those parts and the set up and results
#39
1 Post
Cheers
Cheers
Derek,
964 uses a flap type airflow meter for the ECU that is both restrictive and relatively inaccurate at estimating the amount of oxygen getting to the engine. A MAF is a mass air flow meter that uses a platignium wire to calculate the "mass" of oxygen. It's not a simple swap as you need an electrical box of tricks to convert the MAF signal into one the ECU believes comes from the original airflow meter.
#40
Originally Posted by tonytaylor
Sunroof delete will be way of a "new" roof skin..
I haven't driven an RS or Cup, but would have to think that my car w/ a manual rack, full mono *****, 900/750 springs, and JRZs would feel as good or better than a stock RS or Cup ON TRACK. On the road mine sucks. I have ridden in a 90 Euro Cup a few times (Bob!), but not driven one.
I think w/ no sunroof$$, welded cage$$, better chip, and a R&P$$, my car would be close (as fast) as an RS around the track.
I think a C class/prepared RSA and a D class US Cup car (Euro RS) are about the same and what my car would be if I did the chip and R&P.
#41
1 Post
Originally Posted by forklift
I am still kicking myself for buying a RSA w/ a sunroof and might do this some day, probably when I get a custom cage.
That 30kg sitting up there is eating at my heart and the damn thing doesn't even work anymore.
#42
At least my sunroof works, although since I carry my race tires on the roof, the wind noise is crazy loud, so I really don't ever use it.
I thought about the strip, weld, cut, and re-weld, like Geoffery did. However, that would probably turn my $3k roof into a $23k roof....w/ the car still only worth $35k incl the $12k suspension. I guess I would have an almost new car at that point....after the engine and tranny rebuild. This is depressing, maybe I should just save up for a 996 GT3, it might be cheaper.
#43
#44
1 Post
l This is depressing, maybe I should just save up for a 996 GT3, it might be cheaper.
#45
Originally Posted by SimonExtreme
Not really! They were built on seperate lines and it wasn't simply a case of modifying. The 3.2 clubsport was a modified 3.2 but the RS is different. It was designed from the ground up. It started with the chassis/body (which was modified!!) but much was made just for the RS, rather than modifying standard stuff. Engines were assembled specifically for the car, gear ratios were made, LSD's etc etc. What makes the RS so special is the way it all comes together. I personally think there is a lot of luck in it because only minor changes alter the character noticably. The 993RS looses some of that feel, even though it might be a better all round car, because the changes just dulls it a little.
Noah
