Perfromance upgrade parts.....UK if poss.
#91
Originally Posted by warmfuzzies
Excuse me, but can I have my topic back......
Kevin - is there anything you could do to the car to reduce weight as well as improving mechanical perfomance? Is this a route you'd consider?
Graham.
#92
Weight thing, well it did cross my mind, I don't have aircon. Wouldn't remove the soundproofing or carpets as shes a family car as well as my sunday driver, I had considered the front seats, but not to put too finer point on it my pockets are of limited size this year..... so as I was going to replace the rear exhaust, get one of the RS clutch/flywheel kits, wondered what else I could whilst I was in there so to speak....
Kevin.
Kevin.
#93
Kevin
A race battery would save you a lot of weight, depending what you have already. Inwas already using a msallish battery and saved 6 kgs. If you have a normal battery, you should be able to save about 14 kgs. It has it's downsides, such as not being able to leave the car for a more than a few days without running the battery down. However, this acn be overcome by using a trickle charger, which I know many RS owners do anyway.
Make sure there isn't any redundent junk in the car. I found a 12 year old tracker type system that, once stripped out, saved 3.5 kgs.
#94
Originally Posted by SimonExtreme
Jean
Those companies do remap Motronics but will only provide compete packages to their spec. They will not do custom remaps. I know. I have asked. What do I do if I don't want their menu approach to tuning, particularly as their prices are so over inflated!
OTOH, many of the configurations on these engines have now been done and redone time and time again so the files are out there available, Motronic will adapt quite well to different hardware changes, you can still get 90% there with nothing more than sending your ECU by mail, this would be the very inexpensive option, nowadays for less than $1000 (about 5 gallons of fuel in London? ) you can get your 964 ECU remapped and redone for free if not as you expected.
#95
Colin,
I notice on your website that you to do RR remapping, is this for the stock ECU or? Is this beneficial from a standard car point of view... (964 3.6L Stock 250bhp, Cat / Cup fitted; Up to 295bhp.) taken from the site.
Is there something I'm missing...as I can overlook the obvious sometimes..........
I have to keep my cat fitted as she was registered in 93, so this combined with for starters the flywheel/clutch and Dual outlet exhaust look mightily attractive for a first look.
Kevin.
Kevin.
#96
Kevin
You might need to keep a cat, but not necesarily the standard one. I have not checked for 964's but you can normally get a sports cat with less cells which allows the engine to breath but still gets through the MOT. Or refit a cat at MOT time.
#97
Originally Posted by Red rooster
I am still looking at the Motec answers. No knock for timing/fuel control , no lamda for emmission control and yet this is the best !!!
Geoff
Geoff
#98
Colin,
Kevin.
Kevin.
