Question for MOMO steering wheel owners
I just installed my new MOMO wheel.
Here is the problem. The P/O took off the signal cancel - horn contact ring. So, after finding the horn hot wire its not easy to hook it up without the wire twisting when the steering wheel is turned, for obvious reason.
How many of you who have a MOMO hub have the signal cancel - horn contact? Because from what I can see it would appear that it doesn't fit between the hub and the steering shaft. if you don't have the signal / horn contact then how did you connect your horn up to avoid the twisting when the wheel is turned
Cheers
Mark
Cheers
Mark
