Horn wiring
Horn wiring
I'm trying to reconnect the horn. I have a Momo wheel and because the P/O cut the wires to the airbag and horn to install the Momo wheel, I have no idea what colour wire to connect to the horn wiring.
Anyone know the colour of the hot wire to the horn? The ground is already on the hub.
Mark
Mark
On mine the horn push is grounded to the boss (hub) via a spring in the horn push and then there is a a wire coming from the part of the boss that contacts the spring plate on the turn indicator assembly that simply connects to the horn push.
I have the grounded wire from the horn push. I can't find the wire that delivers the power to connect the circuit. There are 3 wires coming from the column. 1 Blue and white and 1 Brown and White that go to a yellow connector. I have another Brown and White wire that comes from what looks like an in line fuse. I think from reading on here that the yellow connector is the airbag. So, is the Brown and White wire the horn?
Marc, Thanks. I think step 7 shows the wires I have. So, two go to the airbag, which I don't need and the BR-WH must be the horn as it goes into the horn contact / signal cancel, which I don't have!
So, I guess its the single BR-WH to the horn.
Cheers
Mark
Cheers
Mark
