Hood locked shut. Need help!
When installing the battery back after winter storage, I accidently touched the latch with the wrench, causing a huge spark (pls don't laugh). The latch became instantly glow-red. But the hood shut like usual, so I thought I got lucky and nothing happened. Well, I thought wrong - now the hood does not open. Its not the pull handle problem, so its under the hood. Question is how do I get it open.
P.S. The spare is not in there, so I was thinking to drill a hole in the trunk bottom....., but maybe I should keep my hands off off it with my luck.
IHI KING!
Don't sweat it. We all make mistakes. This has been discussed before. See https://rennlist.com/forums/showthre...ease+emergency
no secondary cable on cars pre 1992. However I drilled a 1 inch hole in the floor and pulled the latch open. Now I just need to close the damn hole.
Thanks guys for the input.
Stan
Stan
Technical Guru
