Air Box question
Air Box question
After installing bilstine struts and H & R springs last week my car has seem to lost some power on the top end. I've been chasing this thing around for a week now trying to figure out what I did which was remove the airbox and fan. The mass air was loose in the rubber boot and fell out when I was removing the airbox.
Now, in another thread I posted it was brought up to me that it might be a vacuum leak so I pulled the airbox back off to make sure that the little line is on the vacuum reservoir which it is. Somewhere I read that there is supposed to be a big vacuum line going to the nipple on the airbox. Is that correct? The nipple on mine is blocked off and I can not find a line that would go there.
Is there anything else that would give me a loss of power in the upper RPM's.
Thanks.
Ritchie.
Thanks.
Ritchie.
Technical Guru
I'll check the AFM wireing harness.
I didn't disconect the battery but I was thinking about doing it to reset the DME because before I worked on it the engine was probably sucking air after the mass air flow meter and not getting a proper reading and now that the clamp is tight maybe the computer needs to be reset?
What is the vacumn operated resonance flap?
