I'm obviously insane
#31
yup. full disclosure. he knows what it needs.
I'm sad to see it go.
#32
Yeah, I loved that color.
You'll have another some day, maybe even a 993 next time.
I can't believe I said that...
#33
Gotta say I have 0 interest in the 993. I bought this car mostly because of its aesthetic. Purity of line, pedigree, timelessness.
I've driven every Porsche from 964-997 and every variation in between. I prefer the way the 993 drives but the 964s styling really turns me on. In fact every subsequent iteration drives 'better' but that doesn't mean anyone should care.
#34
I agree wholeheartedly, I was just being a smart-aleck
I've only driven 964's, but they have everything I bought a Porsche for, in the right measure. I can't imagine the other models pleasing me any more than this one.
#35
"I'd like to understand what is the problem with the valve here. It's obvious that there is a leak in the valve seal. You think the valve bent, cracked, or burned? Worn valve guide would not show up in a leakdown (unless it wobbles so
much), and the engine only need 1 quart of oil every 2K miles."
axl911
No I don't think bent, cracked, or burned , yet .
If the valve guide is worn , the side ways pressure from the rocker arm , will tilt the valve over to an angle such that the whole face of the valve will not sit on the whole valve seat .
If you look at an old worn valve guide , you will see that the guide is worn away opposite of the pressure from the rocker arm , a groove on one side is formed . This groove allows the valve stem to tilt over . When the valve stem tilts over all sorts of bad things start happening . One section of the valve touches down on the valve seat . This is a bending force and it causes that section of the seat to wear down faster then the rest of the seat . The seat starts out even , the valve touches down all around at the same time with the same force . The heat flow out of the valve head is near even as its going to be . When the valve starts tilting from valve guide damage , the bending , uneven flow past ,
the uneven wear of the seat etc etc etc , starts a chain of unpleasant things . So its best to take care of it asap .
axl911
#36
Originally Posted by Indycam
I'd like to understand what is the problem with the valve here. It's obvious that there is a leak in the valve seal. You think the valve bent, cracked, or burned? Worn valve guide would not show up in a leakdown (unless it wobbles so much), and the engine only need 1 quart of oil every 2K miles.
that's all I got.
#38
you hit the nail on the head. greater performance does not necessarily mean greater enjoyment.
i think it will be interesting to see what people are doing with 997s in 16 years. i've got a sneaking suspicion that only the GT3s, RSs, Turbos and such will be of much interest to anyone.
only time will tell. one thing is for sure...they keep getting cheaper.
#39
I'm sad to see it go too. I love that Avatar. One of the coolest 964 shots I've ever seen. Would you mind sending me a hi-res copy if I PM you my email?
Regards,
Steve
#41
Originally Posted by dfinnegan
+1
I'd love to have a hi-res copy, too.
M
