backfire blowup---resultant high idle speed???
Technical Guru
Originally Posted by drisin80
are you thinking i have a leak elsewhere??? also pulled the idle control valve-- inner part seems to move without any problems.
throttle fullly closed at idle??? how can i tell???
just got in from working on car. problem seems to be throttle not closed completely. what happens now is that since the throttle closes most of the way-- but not enough to engage the idle speed microswitch, the engine slows to 500 rpms. if i understand correctly, the idle speed switch somehow sends a signal to the idle speed control valve which controls idle speed through the dme. my question is how to adjust the throttle cable so it will relax another 3 mm to engage the idle speed switch???? thanks for all the help. tom
Technical Guru
The main throttle cable adjuster is located behind the accelerator pedal. Remember that when you tension the throttle cable the WOT switch should also activate at close to full throttle, you'll hear it click in the engine compartment.
If the explosion bent the throttle plate or the shaft, that is the problem.
Jason: thanks for the pics and your willingness to post them about this and other topics. I am envious of your photography skills. What type of camera is that?
Technical Guru
