Installed Springs struts Possible Motor Problem
Got done installing my Bilstines, H & R Greens today except for setting the ride hight (doing that tomorrow) then its off to the alignment shop. During the install today while I was removing my air box to get to the rear right one the mass air meter was loose in the rubber boot that it slips in to. It would pull in and out. I continued to remove the air box (broke one of the little rubber mounts that hold it to the intake so I didn't try to remove the other one) but I did remove the box from the mass air meter and moved it out the the way enough to get to the nut I couldn't remove. While the mass air meter was loose and hanging there I remove the clamp and flipped it around so I could get to it to tighten it up when everything was replace which is what I did.
After everything was put back together I took the car for a test drive and it doesn't seem to want to pull as hard in the upper RPM's like It used to. I'm wondering if there is something wrong with the mass air meter or if it was sucking air on the back side of it before and now that it is not the computer needs to be reset or something.
Is there a way to check the meter? Would I be getting a check engine light if it wasn't working right? This is the first 80+ degree day I have driven the car in so it could be something else.
Also, does anybody know where I should look to get that little rubber mounting piece that mounts the airbox to the intake. Also I have a 90 C2.
Thanks.
Thanks.
Did you do the shocks and springs yourself? I am about to do the same set up? If you did it yourself, how long did it take you? Any advice or pointers would be helpful.
I just did mine, one day for the rears and one day for the fronts, including all the time to clean the wells.
You will need an assistant to push down on the rear wheel to get the bottom of the shock to line up with the trailing arm when you go to reinstall.
I had about a day and a half for mine. Not too bad. I invested in a pressure bleeder for the brake system and it helped allot to get the brakes bleed by my self. Highly recommended.
Burgled
It took 2 of us a little over a day to do 2 of our cars. The first was a learning the 2nd was easier except being a TIP a lot of plumbing was in the way on the left rear top bolts.
If you removed the entire air-filter box from the engine, did you remember to plug back in the vacuum reservoir that is attached to the filter box? It has a vacuum line that goes back up to the manifold - if you didn't know it was there, it's easy to not know you unplugged it, especially if it gets unplugged at the reservoir versus the manifold because it's hiding from you down on the back of the box.
Super Duper Moderator
Marc
I had my AFM off a while ago, when I put it back on it did not slip onto the boot correctly. I rolled the boot over when it went on and there was a leak there.
Check that the AFM is in the boot all the way and it is sealed all the way around.
