1990 964 Front Caliper PIston Diameter
I want to order caliper rebuild kits for the front calipers on my 1990 Carrera 2, narrow body. Does anyone know the correct piston diameters. Pelican Parts does not list the size for a 1990 964. Thanks for the help.
Jim C.
Jim C.
Technical Guru
You want 36mm and 40mm and if you are ordering dust boots and seals you should try Zeckhausan. ($50/caliper)
You will also need some assembly paste, Porsche part no. 000-043-117-00. If you would rather source it locally Porsches uses Klüberfluid 9 R 100 and Unisilikon TK44 N 2
