964 Forum 1989-1994
Picture of 997 lobster claws on 964?
Old 03-06-2007, 11:42 AM
R6XTERRA
R6XTERRA's Avatar
Default Picture of 997 lobster claws on 964?
Does anyone have a picture of the 997 lobster claws on there 964, I have seen them on a white 993 and they look good.
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
Like these ones.
Jeff
Old 03-06-2007, 11:47 AM
FotoVeloce
FotoVeloce's Avatar
I doubt they would fit. I know I certainly can't put my 993 wheels on my 964. The offsets in the rear are WAY off. The rims hit the control arms well before they met the hub.
Old 03-06-2007, 11:53 AM
R6XTERRA
R6XTERRA's Avatar
They gave this as the offsets. These won't work?
18" Carrera S wheels. Sized (2)18x8et 50mm and (2)18x10et 65mm for narrow body cars. We also have these in 18x10 et47mm for Boxsters.
Old 03-06-2007, 12:26 PM
FotoVeloce
FotoVeloce's Avatar
964's are typically 50 in the front and 55 in the rear (mine is anway). The 65 offset 18's that I tried to toss on my NB 90' C2 964 clearly would not fit due to contact with the trailing (lower control) arm.
I would have been happy if they had.. but no luck, at least for me.
EDIT: I'd imagine (I don't know for sure) that the 47's will fit, at least from the standpoint of not hitting suspension parts. If they will clear the outter wheel-well I don't know. I'm sure someone else will chime in here...
Old 03-06-2007, 01:19 PM
rotorheadcase
rotorheadcase's Avatar
47's will indeed work as I have my 18 x 10s in ET47 and fronts 18 x 8 in ET48...see the avatar pic for the wheels. A little rubbing up front at right full lock and none at the back even under full load
Neil
Old 03-06-2007, 01:26 PM
Southampton76
Southampton76's Avatar
Put a 17-21mm spacer in the rear, to reduce offset so they will fit. 5mm spacer up front if you want to make sure no rubbing
Old 03-07-2007, 12:17 AM
Cupcar#12
Cupcar#12's Avatar
ET65 can be made to work on the rears
FYI... the Cup I 9.5 wheel is ET67 with a 20mm spacer
you must use longer studs for the rears
Old 03-07-2007, 12:37 AM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
My 18" rears are ET65 and work well with a 21 mm spacer.
Marc
Old 03-07-2007, 01:10 AM
LA964RS
LA964RS's Avatar
Are those aftermarket?...i thought they were all 19's....and yes ET 65 work fine. I'm running w/15mm spacers w/the 21 you need to run more neg camber than I wanted to, but it does fill out the wheel well better at 21.
Old 03-07-2007, 08:41 AM
puma1824
puma1824's Avatar
Taken from the add:
"Hello this is a new set of aftermarket 18" Carrera S wheels. Sized (2)18x8et 50mm and (2)18x10et 65mm for narrow body cars. "
Old 03-07-2007, 10:44 AM
R6XTERRA
R6XTERRA's Avatar
thanks for the advise guys.
I am looking for a new set of wheels just for this summer. I want to sell the cup 2's that are on the car now. Car should be here in a day or 2.
The car will be going turbo widebody next winter and I will be selling those wheels as well.
I will be going with a set of cargraphic 19" deepdished once the car is widebodied.
Where should I get the spacers and longer wheel studs?
Jeff
Quick Reply: Picture of 997 lobster claws on 964?
