Battery/Hood Issue
Battery/Hood Issue
The battery on my 1993 C2 Cab recently went flat and I had to re-charge it.
After I reconnected the charged battery and fired her up, the Cabriolet warning light remained lit and won't go out.
I haven't tried to operate the hood yet as the weather is currently wet and windy and I am worried that I might not be able to get it back up again.
Anyone any ideas or suggestions??
Normal in a cab - whenever you disconnect the battery /drain the 12v supply the light stays on until you lower and then raise the roof. You don't have to undo it the whole way - just down slightly then back up again will cure it.
