964 Forum 1989-1994
Scantool Diagnostic 19 pin Plug
Old 03-02-2007, 09:27 PM
ddubois
ddubois's Avatar
Here's a simple connector I made.
1.) Go to Radio Shack and buy a Molex pin connector for PC power supplies. They are the perfect diameter.
2.) Go to post #51 of this thread https://rennlist.com/forums/showthre...ferrerid=49328 for the Amp drawing and make yourself a 1:1 scale template of the pin locations (7, 8, 10, and 12).
3.) Steal one of your wife's or girlfriends 1/2" thick (or thereabouts), nylon or plastic cutting boards.
4.) Get a 1-5/8" hole drill and drill out a 1-1/2" dia plug from the cutting board. You may want to drill out two because you will likely mirror your first attempt at drilling the pin pattern. It's your decision whether you want to return the cutting board.
5.) Using your template locate the pin pattern, drill, and simply push the Molex pins through after soldering the wires to the pins, and carve in the 3 notches to key it.
Total cost: about 5 bucks
Old 03-03-2007, 09:10 AM
hawk911
hawk911's Avatar
I'd be in for the $25 part
Old 03-03-2007, 11:16 AM
Bluey964
Bluey964's Avatar
I'll have a $25 part if you can ship to the UK
Old 03-03-2007, 12:08 PM
warmfuzzies
warmfuzzies's Avatar
$25 I'm in on that too.
UK caveat applies
Kevin
Old 03-03-2007, 01:05 PM
cwrm4
cwrm4's Avatar
I'm in at $25.
Old 03-03-2007, 01:28 PM
IanR
IanR's Avatar
I'm in for $25, UK as well
Old 03-03-2007, 01:33 PM
merrick
merrick's Avatar
I am in for $25.
Old 03-04-2007, 07:57 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by mojorizing
It uses #7,8,10,and 13 for the pins (ignition must be on), but adding pins would be trivial.
I know Doug B's software only requires those four pins but can I make the suggestion to add pin #14 (RPM) and #19 (Knocking) to future-proof your connector.
Old 03-04-2007, 08:30 PM
JerryW
JerryW's Avatar
For $25 I'd take one too.
Old 03-04-2007, 10:08 PM
AndrewM
AndrewM's Avatar
I'm in once I get my new to me 89 C4 from New York!!!
Old 03-04-2007, 10:17 PM
chewg
chewg's Avatar
I'll play too for $25. Count me in.
Old 03-05-2007, 11:37 AM
greenjt
greenjt's Avatar
in
Old 03-05-2007, 12:16 PM
dcbailey
dcbailey's Avatar
I'm in.
Old 03-06-2007, 01:42 PM
mojorizing
mojorizing's Avatar
Good suggestion, Jason. I just bought 6 conductor shielded to add the two pins. Tell me something, should I use pin #13 or #12 for power. I thought that the car should be warmed up, and idling to read meaningful codes,settings and to do the idle adaptation, which implies the scantool should be powered from pin #13.
Thanks, Kevin
Old 03-06-2007, 03:13 PM
JasonAndreas
Technical Guru
The Bosch hammer uses pin #12 but the control units will only listen to the L line if Term 15 is live, except for (I think) the alarm or the airbag control unit? There are certain features/functions that are missing from Doug's software that require the engine to be turned off but that won't affect your choice of pin #12 or #13. I would stick with what the Hammer does.
Quick Reply: Scantool Diagnostic 19 pin Plug
