Turn Signal Assembly repairable???
My left turn signal will not cancel - right does. I plan to pull the steering wheel and look at the plastic ring ( for canceling turn signals) but fear this is not the problem, because the right does cancel.
After researching the cost of a new assembly and finding no posts about repairs I am loosing hope.
Has anyone tried this ?
Earl
Earl
I had this problem on an earlier 911 and after purchasing the switch found it was an easy repair.
Don't know if that is the case but I have a similar problem where it will not lock in on left hand signal and will not disengage on right. I was planning on taking it appart this weekend and see.
Assuming I can get to it, I will post what I find out.
"Care share the experience?"
Send me a round trip ticket and sure .
Or are you asking how ?
If you are asking how , when you move the turn signal lever up or down a latch gets engaged , the latch has an arm that sticks out , the wheel has a ring with bumps on it , the bumps push the latch arm out of the latched position . If it latches left and right , but only cancels one way , the latches are ok , the bumps are ok and one of the arms for unlatching is ok . One unlatch arm has gone south .
Rebuild the bad arm and if you do it well every things cool .
The other way to fix it is to remove the other arm and just turn off the thing manually .
The arms can never break off again ....
Removed and disasembled mine this weekend. SImple fix although too many loose pieces to take pictures and make sense of.
My problem was that the turn signal arm is plastic and there is a wedge that is part of the arm that holds the spring at a specific tension and location. This plastic wedge broke off. I was able to jam a washer in its place and then I epoxied it so it will not move or fall out of place and create a short.
You must grind off or drill out the rivets to access the arm but it was easy enoough to pop rivet back together again once all the pieces were back in place and the cover repositioned which was the most difficult part. I feel this should be stronger and last longer than a replacement. I would consider this job to be a 4 out of 10 on the difficulty scale.
Just remember you need to discharge the air bag for a good half hour before removing.
Cobalt,
Thanks very much. I hope to take a look at this in the coming weeks - very much appreciate you posting you experience. Did you have to replace the plastics "ring" also?
I may pm or post, if Ok with you, some questions when I get deep into it.
Earl
Earl
Originally Posted by e911
Cobalt,
Earl
Earl
Wish I could have taken pictures but was crunched for time and did not want to loose any pieces. It is a little trick with all the springs and contacts but not that difficult.
I only had to compensate for the missing piece of plastic on the one side of the arm. Once you get inside you will understand what I am talking about.
PM away, although I will be at Pocono this coming weekend so don't expect a response until next week if it is over the weekend.
e911
"Did you have to replace the plastics "ring" also?"
The ring is a big heavy duty part vs the little arm . Never seen or heard of one breaking .
The ring with the bumps on your car is fine , it bumps the one arm thats still ok on your car .
Super Duper Moderator
Mark as usual you compliment this forum with another great write up. I wish I had read that before I did mine but it did not take me more than an hour to take everything apart. The hardest part was getting a bite on the 8mm bolt that locks the unit in place. I also have the computer controls which you do not which required me to remove the arm and then unbolt the switch before being able to remove it.
