It's hot in here!!
It's hot in here!!
Does anyone get alot of heat coming from the RHD of inside doorsill?
With no aircon some days the flaming heat in the car can make you feel uncomfortable, does this happen with anyone else's car?
Are your pipes alright ?. I had my foot being cooked until I found I had a split ducting pipe. On another thread someone was cooking one of the under dash control modules due a hole in the ducting. If you have to replace one, I found that ducting (Eberspächer) from truck parts stores is very good. IIRC it's 80mm diameter
HTH
HTH
I had the same problem and it was the flexible pipe behind the panel where the Hammer plug in point is located. No need for a mechanic, a new piece of pipe, a couple of jubilee clips and 5 mins was all it took.
