Headlamp hole
Headlamp hole
I rock found my headlamp...wondering, should I replace it with something other than stock. Any advice on what should be put in there?
Well the H4 conversion will be just under $500 plus a bit of labor. Xenons gets closer to $2k and you have to upgrade wiring etc, and some of the kits don't have hi-beams.
I have the H4 with the Sylvania Silverstar H4 and they are a marked improvement over the H5 in terms of beam pattern and brightness. You can find full conversion kits at AJUSA or if you are looking to source different parts, do a search in the forum. Many guys have converted to H4 with very nice results.
http://www.ajusa.com/cgi-bin/pb/list...41d5df2ae85c20
http://www.danielsternlighting.com/p.../products.html
thanks for such good information. I had no idea that the lights were so expensive.
I did a search for H4 bulbs and the prices seemed to be around $80...obviously, there is more to it than replacing bulbs.
Technical Guru
Is it possible to only replace the H5 lenses with those from the H4 ($43USD)? Bi-Xenon (low & high beam) H4 kits are available for $300USD so if we don't need the whole H4 headlamp assembly it wouldn't cost that much for a conversion. The only thing I wonder about is the quality of the chinese xenon bulbs.
