Show me your 964 with aftermarket wheels
#215
#216
Rolled fender lips? I'm calculating how to achieve similar flushness w/ my OEM 7/9 +55 Cup IIs. I think I need a 15mm spacer in front and a 20mm spacer in the rear.
#220
The fenders are rolled, there is a slight rubbing in the front when donig a full turn and hard compression.
Think the car might need to be a few mm higher.
The 0,5 gives that little extra Thomas..
#221
if you are happy with this guy's fitment, then you can:
(a)use the online calculator to measure the hub to rim outside edge of his fitment, then
(b) with your narrower wheels, do the calcs to work out what spacer is required for the same hub to rim outside edge.
#222
