Random 964 Picture Thread
#6063
Thanks. Yes to both. Corner balancing is somewhat challenging when trying to get the right stance too. May need to raise the ride height at tad and more camber. I got a little rub on the front drivers side when I did a fast sweeping right with little dip/bump mid turn. I adjusted the PPS10 from 5 - 7 and tried it again with the same rub. May try one more notch stiffer before adjusting the height and camber. Car is a dream
#6065
In 2 weeks my car will also be corner balanced etc..
I'm very curious what they will do with the ride height.
#6066
#6067
#6068
<----a mug each of Orval and Achel
#6069
Thanks. Actually the rear does sit a touch higher. Wouldn't more rake make it more likely to rub. I'm going to first adjust the suspension stiffer if that improves anything. If that doesnt work I may just need to raise it touch or a little more negative camber. If that doesn't work then may need to make some minor adjustments to the geometry to keep it this height. On a smooth twisty road not an issue just when I have some aggressive compression such on bump is there minor rub. We'll tinker with it and get it perfect. Sebring is bumpy track.
#6071
#6072
No not yet. Today is my first day driving as setup. Rolling the fenders is a final option if we cant get the geometry right or have to raise it to the point where the look is gone. But for me, I have always been a guy to do mods that can be returned to stock. That said, if I can't get it the way I need it then roll away
#6073
Here's mine after a wash...
Two bucket method
Two bucket method
#6074
The 964 Rs has rolled arches from the factory 😉
