964 Forum 1989-1994
Rear sway bar for a Tiptronic
Old 12-04-2005, 08:45 PM
mojorizing
mojorizing's Avatar
Default Rear sway bar for a Tiptronic
I'd like to upgrade my stock 19mm rear sway bar to 21mm. My sway bar has a couple of offsets to clear the transmission...will all sway bars offered for C2 w/ manual transmission fit my car or I'm I stuck with this 19mm?
Thanks, Kevin
ps. does any one have a 21mm rear sway bar they'd like to sell?
Old 12-05-2005, 11:55 AM
Syd B.
Syd B.'s Avatar
Just curious, but do you track your Porsche? I can't see how this upgrade would appreciably impact handling characteristics, other than under the most severe driving applications. I would think that a properly installed roll bar (which you would want in a track car) would do more for body rigidity than upgrading the rear swaybar. Also, I am assuming that you have installed a front strut bar already.
Old 12-05-2005, 12:11 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Syd,
A larger rear anti-sway bar will not help to increase body rigidity but rather will help to reduce understeer.
Marc
Old 12-05-2005, 03:22 PM
mojorizing
mojorizing's Avatar
Auto X only. I'd like to reduce the body sway going thru fast tight turns like the one sees during auto x events and trying to find parking at Costco.
There's not much to the stock setup...split rubber bushings,etc. Not very tight, if you ask me.
My car sways like a drunkin' sailor, and I've gotten comments to that effect while out on the coarse. Other than that the car behaves well.
later, Kevin
Old 12-06-2005, 12:08 AM
PC2
PC2's Avatar
Kevin,
I've tracked my Tip for 2 years and have found the stock bars to be adequate and pretty neutral. I also did not notice too much body roll with my setup, as a matter of fact, I could almost lift my front wheel during high G turns (I'll post the pic if I find it). My setup was stock sway bars, Bilstein HD's with H&R RSA/Turbo springs, and front upper strut brace. Alignments & ride heights were dialed to Eruo RS specs.
There was a thread from about a year ago regarding sway bar choices and I remember Adrian saying the 19mm rear bars on a Tip C2 to be a good match.
I hope this helps.
Old 12-06-2005, 12:14 AM
mojorizing
mojorizing's Avatar
I should look at going the Bilstein/ H&R route on my suspension.....Hey Santa, take note of this!
Thanks for the info, Peter.
later, Kevin
Quick Reply: Rear sway bar for a Tiptronic
