Caution on Rear Hubs
Technical Specialist
Lifetime Member
Lifetime Member
We've had a number of 964's that see track time require wheel bearing replacement, both front and rear. In itself, that's not bad, just maintenance. However, we've also seen in our local region several that suffered broken rear hubs, with the failure point being around where the shaft of the hub joins the outer side of the wheel bearing. When a hub breaks there, you have the rear wheel held on by the axle nut, not a good situation. Don't know for sure whether a bad bearing causes the hub to fail or what exactly causes it.
Reason for mentioning this...I'm replacing my wheel bearings, and in inspecting my rear hubs, one of them has two slightly visible cracks started, enough that I'm replacing it. I'll probably get the other magnafluxed to ensure there's nothing starting there too, although it looks OK.
By the way, are you (or the other cars that had failures) running 18" wheels per chance??? Or do you have spacers so the offset of the wheels is no longer factory? I am curious what the etiology would be...
My wheel bearings (front and rear) have been failing after about 20 track days and have been a yearly replacement item. While I think that some of the problem came from using straps thought the wheels to hold my car to the trailer, I'm going to be buyiong a puller so I can learn to change the bearing myself (at the track). I run 17" wheels with 6 mm spacers in back and had been running with no spacers in front (just added a 6 mm).
Any suggestions on what puller to buy?
Bill, thanks for the post, I'll pay extra attention to the hubs when I do my next service/checkout.
Lifetime Member
Lifetime Member
I'll check mine out next time I swap my tires.
Lifetime Member
Lifetime Member
Lifetime Member
Lifetime Member
Super Duper Moderator
Bill - could you add a photo so those of us who are less technically inclined will know what to look for (and exactly where)?
Thanks.......Marc
Thanks.......Marc
Lifetime Member
Lifetime Member
And in case you're wondering, 964 hubs are a stocked part by Porsche, and they run around $375.
Originally Posted by Bill Gregory
....A friend bought SKF? bearings made in Brazil, which only held up for a year.
Hope I'm not hijacking this thread but it is related..........
I'm interested to know what the signs of hub/bearing wear or damage might be. Reason being that my right rear wheel has a ticking noise which has recently got very noticable and is getting more and more "intense" - especially on right bends (!). I've pulled the wheel and can see nothing catching or rubbing at all and I don't have any symptoms I would normally associate with bearing failure ie grinding or roaring noise.
I'm beginning to think it must be the hub or the bearing especially as I've recently changed back from 18" to 17" wheels and last year that wheel got hit fairly heavily in a spin. Of course the OPC who did the repairs didn't pick up any problems in that area (of course)
Any thoughts anyone?
Lifetime Member
Lifetime Member
Thanks Bill. Thing is the axle on that side was replaced about 1 year ago as a complete unit/CV joints etc, as you mention. Thats what made me think it must be a bearing. Either way sounds like its not something thats going to go away so I'll have to let the OPC check it out I suppose. Feels like another big expense in the offing.
Lifetime Member
Lifetime Member
