View Poll Results: Clay treatment - opinions?
Voters: 85. You may not vote on this poll
Clay bar treatment - poll
Originally Posted by Christer
Does anyone know whether a clay bar will help with the pink discolouring that I have found on my car in the last few months?
I think the short answer is probably - No. The loss of pigment in Guards Red is due to the oxidation of the paint layer (there is no clear coat on Guards Red) and the only way to restore it is to remove the top layer of paint. There are a variety of rubbing compounds on the market - T-Cut is probably the most common. They are all quite abrasive so care is needed but the results can be pretty good as long as you are careful.
The clay bar will only remove surface contaminants - not paint.
Regards
Dave
Graham, I've used the Zymol clay bar with mixed results, yes it does do a good job of cleaning the paint but on my black car it seems to pick up the dirt then leave loads of swirl marks no matter how much I keep turning the clay bar, and I keep it well lubricated, I must be doing something wrong i guess.
Cheers Andrew
Cheers Andrew
Cheers Andrew
Cheers Andrew
To anyone considering using a claybar - your car must be very well cleaned before you start using it, or the action of using the clay could push any remaining grit into the paint and cause scratches.
Oh the joy of Guards Red!!
Mine suffers from this and the best ways I deal with it are :-
1. Use Autoglym Paint restorer (cut the top layer back) then polish. This has the 'longest' lasting effect of keeping the paint red.
2. Use the cheap Halfords Zymol polish, this brings the red back but doesn't last as long.
Neither last too long and I have found the fading is worst when you get rain and sun. I assume the water droplets magnify the UV.
I found the Halfords Zymol brings the red back with the minimum amount of work. Just a gentle application of the polish seems to restore the colour, easier than other brands.
I'ld be very interested in what others have found and how they deal with it.
Richard
Greg_L, I used fairy liquid as you said, but I thought that the clay bar was for removing all the dirt, insects, road grime, and stuff.
so whats good for swirl removal on black paint work
cheers Andrew
cheers Andrew
Claybar's are really for the harder to see dirt 'specs', the minute stuck on sap droplets, and the tiny tar spots that appear all over and are hard to see on black paint. If you get the insect residue and everything else off first with the fairy liquid and a cleaning mitt/sponge, the claybar won't get so clogged up with krud and will work better. Thats what i found anyway.
As for anti-swirl i can't remember if the Zymol (titanium starter) kit i have, had an anti swirl wax or not. But i use a Zaino product now called "Z-5 Show Car Polish for Swirl Marks and Fine Scratches". After the fairy liquid, then claying, i applied 4 coats of this stuff, with a dab of gloss enhancer spray and a buff in between each coat, then 3 coats of the "Z-2 PRO Show Car Polish for Clear Coated Car Finishes". Afterwards i had a very sore arm, but the results were great
I took this photo as soon as i'd finished : http://www.carmovies.net/gallery/964/911_Zaino_6
But what I want to know is why has my front left wing suddenly oxidised over a very short period? The resof the car is not affected....? Bu thanks for the suggestions, I will use an HD cleanse first before I try a more abrasive product...
Originally Posted by Richard H
Resprayed at some stage?
Or perhaps you park it under something whereby only the wing see's the sun each day ?
