Clock Repair/Airbag Light DIY
For those who would like to see the original post with photos:
http://p-car.com/diy/clockrepair/
I also got the airbag/seatbelt lights on yesterday so I have resoldered all of the pins and now need to clear the code to test. Thanks very much to the original author of the DIY! I used solder wick (instead of a solder sucker) to remove as much of the old solder as possible and resoldered the pins using fresh stuff. Hopefully that will do the trick.
i could not remove the small ground connector - i was using pliers and was giving it some muscle, but didn't want to break the pins or the wire. any tips on how to get the connectors off?
Hi
I followed the instruction posted by David Ream, and re-soldered all the solder joints on the clock.
I was hoping that I was on easy street, but after one mile or so, the light returned.
Any suggestions?
Don
Any suggestions?
Don
HI
A quick reply to XCOLDRICEX
Both clock connectors, the big one (white) and the ground one (black) have a latch that needs to be squeezed or compressed.
Use needs nose pliers to unlatch the latches.
I just completed the task, to no avail, and notices your post.
Don
Don
Same thing happened to me. Re-soldered clock - lights cleared with a hammer - then lights go on again.
Don't forget the lights will only go off when you clear them.
To fix the problem my mechanic switched the airbag sensors. They are both in the frunk (left and right).
Don't forget to disconnect the battery first. The sensors are held on with tamper proof screws - but with a long extension and the right size socket they can be removed.
The right side sensor is located under a washer fluid reservoir and after 25 years of spilled fluids was corroded. The sensor itself was OK, but the ground was probably making intermittent contact.
I feel that cleaning the contact would have solved the issue without swapping the sensors, however a hammer will tell you which side sensor is not working (I think) so swapping them is a way of tracing the problem (I think). It's been a while...
Anyway hope that helps. It worked for me.
As Simonstorey offers, disconnect and clean the air bag sensor connection in the frunk before doing anything else.
I had the same problem with the airbag/seat belt lights coming on every time the car sat out in hot weather. I would keep resetting the light with the T-OBD cable and software and eventually the lights would stay off for a few months but eventually come back on. Finally I got tired of that and bought a new (used) clock and the lights still came on. So, I finally cleaned the air bag connector a couple of years ago and the lights have never come back. Ironically it was very easy to do following some threads on RL compared to resoldering the clock.
Here is the thread I followed:
https://rennlist.com/forums/964-foru...with-pics.html
air bag lights
Hi
I suggest you clean the contacts from the two sensors first. I did the clock resolver, and it did not fix it, but after the connector cleaning, the fix has worked now for a year or so, without reappearing.
DIS
DIS
Checked the contact in both sides, clean as new. With durametric I get the following fault codes. When clearing the codes the airbag light goes off for a half second and lights up again. Haven't found what the codes stand for. Anybody have ideas what they are?
Air bag lights
Hi
I do not know what those codes are, but I suggest that you clean the contacts with alcohol and some other contact cleaner. I used WD40, but was told that is bad. I just used a Q tip to clean the contacts and lube them.
Be sure you clean both connectors which are in the "trunk" under the carpeting, on each fender well. They are not easy to get to.
Do the lights just pull out? I don't have airbags anymore nor factory seats so don't want the lights on anymore. Further, they would go on after a reset anyway...
Problem to this was found. The isolation on the cable between controller and passenger airbag was damaged. Cable fixed and it was possible to clear the codes. Life is good!
