C2 Weight
What is the "normal" weight for a 1990 C2, for the sake of argument, the number that could be found inside the door jamb?
Thanks! |
Hi Thom,
I'm guessing you're already calculating how fast your "lightweight" 2.7 will be with the 3.6L engine :) . Looked inside the door jambs of my car, and all I found was a GVWR = 3693 lb. Also found a GAWR = 1499 lb. /Rear = 2315 lb. Found a capacity rating of 661 lbs. in the engine bay. 3693 - 661 = 3032 lb., which happens to be a one pound difference from the factory published curb weight of 3031 lb. for the C2. I think this weight (the curb weight) is what you were really after? Just for completeness, the factory published curb weight for a tip. C2 is 3100 lb, a C4 is 3252 lb. Hope this is what you wanted. And, best of luck to you on the engine installation! |
