Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   964 Forum (https://rennlist.com/forums/964-forum-59/)
-   -   Has anyone had to replace their door straps? (https://rennlist.com/forums/964-forum/229982-has-anyone-had-to-replace-their-door-straps.html)
Frank F 09-29-2005 01:11 AM
Dear All,
I think they are called 'door straps', however please correct me if I am wrong. My doors seem to swing wide open (when opening) without having the option of being partially opened. I have been told that the straps are 'stretched' and should be replaced... (again is this correct?)
Again thank you in advance.
Frank
JasonAndreas 09-29-2005 02:18 AM
Hopefully the two door stay bolts have come loose and you haven't destroyed the inner metal? Did your door ever make a clicking sound when opened?
Frank F 09-29-2005 03:53 AM
No sound at all. Just that it swings wide open.
robmug 09-29-2005 04:33 AM
Yep, it's a fairly easy job too. They don't stretch, there's a rubber block inside which deteriorates over time.
You'll be amazed at the difference; 2 very clear stop points with the new strap in place.
The hardest part of the job is removing the door trim panel as you have to access the strap from inside the door.
It's called the door check strap, by the way.
puma1824 09-29-2005 08:50 AM
So this will repair the clicking? By chance would you have a part #?
DarrylH 09-29-2005 09:10 AM
https://rennlist.com/forums/diy-964-1989-1994-911/197835-check-strap-removal-replacement-guide.html courtesy of Marc Shaw.
robmug 09-29-2005 10:44 AM
Wow - great write-up Marc; didn't spot it at the time but that's a perfect guide to changing the part.
puma1824 09-29-2005 10:45 AM
Originally Posted by DarrylH
Thanks...I knew I should of search before asking.
Frank F 09-29-2005 09:42 PM
Thanks Marc.
Frank
Marc Shaw 09-29-2005 09:55 PM
Originally Posted by Frank F
Thanks Marc.
Frank
You're welcome, glad to help. :cheers:
Marc
(and to think some suggested I just wanted the glory. ;) ).
Graham L 09-30-2005 04:41 AM
I didnt even know mine were broken until I read this thread - I have no intermediate stopping point when the doors open. Now have another job on the list!
Pesty 09-30-2005 11:10 AM
Me too :) looks simple enough 2 bolts and a pin. famous last words :)
IanR 09-30-2005 01:07 PM
Me too!
bhensarl 10-02-2005 07:29 PM
Can someone verify for me the parts numbers for the parts needed to replace the check straps (as mentioned in Marc's DIY, he ordered them as a package from type911.co.uk but I'd like to try to order from Sunset or one of the usual suspects)?
In Illustration 804-00 in PET I found:
-door arrester 964 537 057 00
-screw M6x 14 900 075 374 02 x2
-bolt 911 531 275 00
-safety clip 999 166 008 02
Can anybody verify this?
Brian
Richard Curtis 10-02-2005 09:12 PM
I ordered what you call a "door arrester" last night from Pelican. $26 plus shipping. I think the bolts, etc., were part of the "kit." Yes, your part no. is correct (Pelican's part number is M-537-057-00). Pelican calls it a "door check strap."
