Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   964 Forum (https://rennlist.com/forums/964-forum-59/)
-   -   performance chip--how to access? (https://rennlist.com/forums/964-forum/21608-performance-chip-how-to-access.html)
trish 06-25-2001 08:16 AM
I have a c4 with a performance chip and since it came with the car I don't really know if it's a great performance advantage. However cold starting and running is a problem - the car stalls easily and is difficult to drive while cold. I have been given the original chip and wish to re-fit it. Can someone please tell me where and how it goes! ? Many thanks
Steve Weiner-Rennsport Systems 06-25-2001 02:17 PM
Hi Trish:
Indeed, a poorly-done performance chip is worse than the stock one and I too, would reinstall the original one.
This is found in the DME box under the driver's seat, at least in LHD cars. You will see a silver metal box under there that says "Bosch Motronic" on it. There will be a silver sticker with all of the numbers, Porsche & Bosch on the cover.
Undo the large multi-pin connector and unbolt the box from the floor. Ther are some bendable tabs that hold the cover down.
The tricky part is separating the 2 circuit boards to get at the chip socket on the lower board. You will unsnap the top board at the rear (furthest away from the connector) from thos 2 little white plastic posts and then using 2 little screwdrivers, release the catches on the opposite end on either side of that multi-pin socket. Thes are black and kinda hard to see. Its tricky.
The EPROM is in a socket. Observe carefully the small notch on the end of the chip and R&R the stock one the same way. Do not touch any of the pins on the chip.
That should do you,........ :)
