964 climate controller electronic hum
I just bagan to notice when i turn car off, there is an electronic hum coming from the climate control unit. This hum goes on for a few minutes then turns off.
Anybody know what this is?
Mike 91 C2 CAB
Mike 91 C2 CAB
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Mike,
Is the weather somewhat warm where you are. This maybe the rear blower fan running down which tends to put what seems like a hum through the vents above the control unit. Had me stumped for a while.
Ciao,
Adrian
911C4
944
PS: Yes guys I am back from a terrific 10 day holiday in Lisbon Portugal.
Ciao,
Adrian
911C4
944
7th Gear
mike, there's a small fan on the back of the climate controller [very small] and it continues after the ignition is turned of-somtimes for some minutes.all perfectly normal I'm told.
Mike,
As Trish said, there is a small fan on the back of the control unit that sucks air through a temp sensor to monitor cabin temp. Mine made a wurring sound which could be heard when the ignition was switched off, like you say for up to a few minutes. Obviously mine was a bit worn. I sprayed a small amount of spray grease into the fan (from the back not through the sensor!) and this quietened it down, it can still be heard just but probably only because I'm listening for it.
Richard.
Richard.
