964 Forum 1989-1994
How to lower a 964 C4?
Old 06-12-2001, 07:23 PM
Rick964
Rick964's Avatar
Question How to lower a 964 C4?
What are my options for lowering my car?
Old 06-13-2001, 08:11 AM
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Adrian's Avatar
Talking
Dear Rick,
I highly recommend you get hold of a copy of the three part article called Wringing Out a Carrera 4. It was published in Excellence, April, Sep and Dec 1992. Well worth a read and tells you everything you can do and what the affects are.
To see the end result check out at web site http://Porsche911.isuisse.com click on rennlsiters, then tech articles then Adrians C4 goes low.
The photos of my lowered C4 are as per the recommendations in these articles. I used EIBACH Springs (964RS) and a full set of KONI Sports Struts and Shocks. Plus a few other little goodies. If changed from the article only in the wheels department. I installed 911 (964) Turbo 17 inch wheels,
Ciao and good reading,
Adrian.
PS: I do not recommend you install H&R Lowering springs on their own. Besides they do not stiffen the ride much on their own anyway.
Old 06-13-2001, 12:58 PM
gregC2
gregC2's Avatar
Cool
Adrian; a "side" question. In America, there's this rubber "block" between the blinkers and driving lights. On the European cars, there appears to be a lens or some piece of plastic there. Is that a light of some sort, or a reflector? Anybody ever changed that rubber block to whatever it is there in Europe or is it a bit of a timely project?
Old 06-13-2001, 08:03 PM
Richard H
Richard H's Avatar
Post
On the European cars this is just a small reflector, clear plastic, nothing else. Not sure if you can just swap on a US car.
Quick Reply: How to lower a 964 C4?
