Caliper Spring Plates
Has anyone replaced their Caliper spring plates?
I had a quick go at the rears recently when replacing the pads but they seem to be on tight. I tried the screws but didn't want to mess up the head of the screw so left them.
Anyone got any tips, use an impact driver?
Richard 1990 C2
Richard 1990 C2
Technical Guru
[quote]Originally posted by Richard H:
<strong>Has anyone replaced their Caliper spring plates?
Richard 1990 C2</strong><hr></blockquote>
I had my fronts replaced by someone that knew what they were doing and they also powder coated them so I wouldn't have to deal with corrosion (again.) The rears I did myself. The screws are held in place with locktite so you will need heat to loosen them. A hair dryer will not work, you need a torch of some sort.
jason andreas
1993 964RSA
jason andreas
1993 964RSA
