Seal on Oil cap
Seal on Oil cap
Hi All,
While checking over my engine yesterday, I tightened up the Oil Cap as there was maybe a 1/16th more turn. What a difference. Idle now solid, acceleration much smoother etc.
For those that don't know (and I know Adrian has mentioned this many times), the seal on the oil filler does have a big effect on running.
Has anyone else noticed this?
Ade.
Ade.
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Ade,
Any air leak in the 964 has a major affect on running. Poorly fitted airbox or filter. Leak in throttle body and of course the often mentioned oil cap,
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
I second that on the throttle body. Mine ran like sh** and when took it to the shop they did a leak down test on the throttle body. It wouldn't hold pressure for even 2 seconds. As the guy pumped the air in it leaked out just as fast. The body is supposed to hold something like 3 pounds of pressure for 10 minutes or something like that. Anyway, what a difference. ($1800 later).
