964 Forum 1989-1994
Rear seat question--964/993
Old 01-09-2002, 12:01 PM
Chris C.
Chris C.'s Avatar
Post Rear seat question--964/993
Hi all:
Are 964 and 993 rear seats interchangeable?
Can I mount 98 993 seats in a 964 C2? Parts catalogue shows 91-94 has top release button seats with very similar mounting points to a 993.
TIA,
Chris C.
Old 01-09-2002, 04:13 PM
MelissaM
MelissaM's Avatar
Post
Chris,
I'm not sure if the 993 rear seats will work in the 964.
I'm also not sure if this matters, but is this for a coupe or cabriolet? I think the rear seats are different (within the model range) for a cab vs. a coupe. (I'm assuming it's not a Targa, given the differences between 964 & 993 Targas.)
-- Melissa
Old 01-09-2002, 05:06 PM
speedster 94
speedster 94's Avatar
Post
hallo
on the 993 the seats are the same for Cab/Cpe
The lockfunction is the same,it locks in the inside Bracket,but sometimes you have drill the hole a little bigger (before 92 Cars ).
I have done that in 2 Cars and it works fine.
harald
Old 01-09-2002, 10:27 PM
Chris C.
Chris C.'s Avatar
Post
All:
The cars are both coupes...yes, Cabs have different rear mounts due to, among other things, the seat belt mounting points.
Can anyone else validate Speedster's experience using 993 seats in a 964?
Chris C.
Old 01-10-2002, 04:34 AM
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Adrian's Avatar
Talking
Dear Chris,
The answer to your question ist Jein (Ja und Nein).
Interchangeability depends upon what you have installed from original and model year of course. I helped somebody else on this list with this very question. We came up with a miriad of options and part numbers. Remember with the Speedster for instance that this was built on a Cabriolet chassis not a coupe chassis so mountings can be different.
Front seats ar emuch easier to deal with than rears. I know much of th trim never fits the same.
The only way to be 100% sure is to remove your rear seats and compare them to the ones you are looking at purchasing.
Failures in this can get a tad expensive,
Ciao,
Adrian
911C4
Quick Reply: Rear seat question--964/993
