964 DME Numbers & settings 1990 C4
Hello Forum:
Anybody Know the DME "Motronic" Numbers ? I am trying to find out if the "right one" is instaled in my 1990 C4 or not ?.Car is a 5 Speed Non Turbo
On top has Bosch # 0 261 200 182
Porsche part # 911.618.124.02 "WHAT YEAR & MODEL IS THIS ?"
Under that it says : TYP 911 MW D2 -01 "IS THIS THE RIGHT ONE ?"
(Door piller says:Manufacturd by Dr.Ing.hc.F.Porsche AG West Germany 26sep 89) ( vin number is WPOAB2969LS450336)
_________________________________________________________________
Dealer in CA.could not find the Number of the DME thats in my car in the book !
He Thought perhaps it was a non export model but could not find the # that way. Via the Porsche "Dealer" Web site ??? Whats up with that ?
Salvage Yard has one thats one number off. They have Porsche part number
911.618.124.01 ( so its a 01 on the end rather then a 02
Dealer: says the current number is 911 618 124 04 and that 911 618 124 01 is the old number but the right number for a 1989 & 1990 yr model !
I was also told they all interchange from 1989 to 1994 and will work fine ?
I find that hard to belive ? Dealer says 89 & 90.
Mine has a aftermarket "Chip" however I belive the DME needs work or replacing and I would love to know what one's will work. Also if you know whats the DME adjustment for ( Plug on side of cover to reach adjustment)
Have anything to do with the Motor Idle by chance ?
Thanks much if any body knows
Apeper
Apeper
Technical Guru
Thanks Jason:
Thats good information as the old numbers are no longer of the local dealers book / Web site. So the Dme 911.618.124.02 is the right one for the car. Made end of sept. 1989. Info about later to early units also usefull. I spent the afternoon at a Porshche Raceing & Repair Shop ( Came beer in hand) and found that the adjustment is for idle and sets timeing. Generaly sets all the way to the left (CC) DME has Autothority Chip-I disasembled the unit and a Video repair friend checked it out, Its fine
I am still searching for any bad part as the car runs poorley at times and has a history of such.Yes the Airbag Seatbelt control has fired the "Lights" and the hammer reads Code 62 but thats all. I do not want to replace it until I find ( or try to find) what fired it off because if I install another control whats to say something will not fire it off again . ( then I will need another one ) Yes everything would need to be checked upon instalation - like the pill rest. etc.No I did not instal the battery backwords thanks for the input. The "good news" is that I discovered that Air-Flow box & unit is hanging up and causing poor running. I fooled around with it and it is runing fine so far. I think I shall install a DELCO unit in with some voltage adj.(they fit and are like to a 1995 type) Perhaps the Control ( Airbag) failing is within itself or was fired by my finaly discovered bad DME relay. I can tell you one thing I shall be standing to the side upon turning on the key as I heard the story about the Insurance ADJ. inspecting a wreck and upon turning on the key to read the millage (later model ) was killed when the AirBag fired.
Thank you Jason - Happy Motoring
1990 C4 Never Wrecked Allways Pampered - Battery in Right- Apeper
