need Super Cup cam info
Looking at purchasing a 90 3.6, which has Super Cup Cams. anyone know who different these are from the standard 90 3.6 cams? what will it do to power output.
It is a bit vague to say 'supercup cams', can you find any pevious bill history for the work that was done or the name of the company that may have carried out the conversion?
The Carrera cup cams that you may be referring to were the same as the standard engine, but the right hand cam did not have the power steering take-off on the end
I hope that this helps!
Phil;
thanks. the seller of the engine had this stated in the description, but it appears that i need more info from him. Is there a specific cam upgrade from my stock 3.6 in my 90?
andy
andy
