Oil Drain Plug
Per the factory repair manuals:
Crankcase drain plug: 52 ft lb (70 Nm)
Thermostat housing (the plug near the passenger side rear wheel): 48 ft lb (65 Nm)
Oil filter console (inside the rear wheel well): 23 ft lb (31 Nm)
I never take off the oil filter console plug (used to drain the oil filter) b/c it requires removal of the passenger rear wheel. Instead, I puncture a small hole in the filter, which drains most of the oil out.
Drew
92 C2
Drew
92 C2
