Uh Oh...put in wrong oil
I accidentally put in 1/2 quart of Mobil 1 Synthetic 15w50 instead of the regular dino Castro 20w50 to top off my C2.
Would this cause any harm? I don't think so, but wanted to make sure.
thanks,
anthony
thanks,
anthony
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Mark,
This is actually incorrect. It depends upon the application. Mixing as has occurred here will have no affect at all. It is not the oil itself that is the problem it is the additives that make the oil do what they want it to do that causes the problem.
Some oil you can mix or change out by topping up others you cannot.
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
