Air Conditioning Compressor Mounting Question
I believe that the air conditioning compressor mount (which also serves a shrouding function as well as a support function) is the same in all normally aspirated Type 964's and Type 993's. Is it different in Turbos and, if so, why?
Thank you.
Thank you.
Perhaps he is referring to how the bracket integrates into the engine tin at the rear (harmonic balancer end) of the motor, which functions as a shroud between the intake side of the motor and exhaust side of the motor (from an air-cooled airflow perspective).
