Rear Sunroof Seal - DIY?
I noticed a strage vibration noise when cruising on the Autobahn yesterday. There was no noise under 180km/hr but it started there and got worse the faster I went. The culprit was a loose sunroof rear seal that was litteraly flapping in the wind and on my roof!
Anyone had this problem and fixed themselves? I was wondering If I could just glue the seal back in place. When I wash the car it has a tendency to slide around and come out of the groove. Sometimes when I use the sunroof, it will fold under itself and not seal properly.
Thanks for any advice.
Cheers,
Mike
Cheers,
Mike
I had the one on my car replaced by the body shop. You have to take out the whole sunroof assy to fix the rear seal. BTW: Do not bother fixing the old seal buy a new one from you OPC they are not expensive.
sunroof seal
I did this DIY today. Getting the roof out is the easy part. Getting that seal to sit at the correct height and actually meet up exactly with the seal on the car is another story. And man is that 3M Super Weather Strip Adhesive a mess to work with. If anybody has any questions I'll offer up what I learned.
c
c
garrett376, the headliner removal is MUCH easier than you think!
Just open your sunroof halfway, pop the front edge of the sunroof headliner off with your fingers and carefully operate your sunroof the rest of the way open and slide out the headliner panel...no roof segment removal is necessary.
OH...in regards to changing the rear portion of the sunroof seal:
1) Purchase a NEW seal...don't re-use, you've gone this far to take the roof section out, do it right.
2) The 3m "Super" Weather Adhesive is messy, use Nitrile or Latex gloves...Nitrile is MUCH easier to work with as the Latex tends to stick to the project more than desired.
3) YES, it is very much a DIY project for the non-Rubik's Cube challenged projects mgr.
***There's an 80s reference for ya!***
4) FOLLOW THE INSTRUCTIONS on the 3M stuff, lay a thin layer of it on BOTH mating surfaces...this will work TENFOLD when compared to the "I'm a guy, don't need instructions" disposition.
I once read a quote about up-grading at Porsche for the track:
"if your car has a sunroof - the best thing you can do is weld it shut....."
Do you use the sunroof? If not can it be removed for head room? Has anyone done this?
I love not having a sunroof in my RSA - Clean lines, no leaking or electrical problems, Structural rigidity, weight, head room (I believe it is 1-3/4" extra - I do not have to adjust my seat to wear a helmit............).
Flagg
Flagg
Originally Posted by C4Expat
... When I wash the car it has a tendency to slide around and come out of the groove. Sometimes when I use the sunroof, it will fold under itself and not seal properly. ...
Thank goodness I found this thread. I got up this morning to find a puddle of water behind the driver seat (not to mention water running down the side of it). It was dripping out of the head liner right next to the light. ****.
I'll try to do this myself... I think the car seal needs replacement as well, might as well do it all right, right? If I manage to succeed in this, I'll post some picts and thoughts on the process. Right now I'm just miffed I had to move the 964 into the garage and get the other car wet and dirty today.
Originally Posted by Jeff Curtis
I'll second that vote for clogged drain tubes!
EZ fix.
EZ fix.
One more for the tubes. The seals don't really "seal" anything. They just keep debris out of there. If you've got a wet interior then your tubes are clogged.
LOL. I'm a tard.. sheesh. I all up and ordered new seals all around.. now.. it makes sense.. looking at them.. like.. how in the world do those seal? They don't!
Well.. I have an all-new set of seals coming in case I ever need them.. :/
THANKS for the info on the drain tubes. I'll scrounge the site for the fix info... might need to go and buy some wire to clean them out but that's doable.
Sheesh.. what a dope I am.
Thanks guys.. again... and again... and again.. . this site kicks butt!!
Now.. my 993 has a REAL leak at the base of the windshield that I need to look at. Thing is I can hear a faint whistle of wind lately and putting my finger around the base where I saw a drip of water, changes the sound. DOH! More fun with seals!!!
