Oil tank
Lifetime Member
Lifetime Member
Oil tank
My 964 is in need of a new oil tank.
Finally, after months of trying, an oil-leak has been traced to the 'hidden' face of the tank, which has become porous.
Has anyone ever come across this before and does anyone know the cost (pref. UK) of a new tank?
Hello
never had seen that, very comon are rustet trough oil level sensor plates and corrosion where the dirt was stuffed into and winteruse.
if you remove the tank be prepared to renew the long hose from the oilfilterconsole and the two short rubber hoses from the tank to the thermostate the bellow into the body and the knee from the enginecase to the long hardline at the suction side.
Grüsse
Grüsse
Hi there maybe of interet for you!!!
Just found a used oil tank for a 964 on e-bay in Germany. You may have a look from tjhe picture it sems to come complete with every hose. Hope this helps: <a href="http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=1760729942" target="_blank">http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=1760729942</a>
Greets THOMAS <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Lifetime Member
Lifetime Member
Thanks, but I have ordered a new tank. I have spent soooo much chasing this oil-leak that £400 more to finish the job will be money well spent.
A tip for others that may follow - any oil-leak which seems to be from the thermostat area (where there are many, many pipes and unions), check it's not actually comimg from above!
Hello
never had seen a rustet trough 964/993 tank and if they had rust they had isurfacerust on top or on the inside wall.
Have a good look to descripe or make pictures to inform the board.
Would help others saving money on searching the problem.
Grüsse
Grüsse
