Flag mirror question - disassembly?
Anyone know how to disassemble the glass/mirror from the flag mirror housing? I want to remove the OBC temperature sensor from the driver's side flag mirror and reinstall it in the aero mirrors that is currently on the car.
Thanks and happy new year everyone!
Do you mean just taking out the mirror from the housing? Aim the mirror down and in as far as it will go. You will see a ring at the top center of the mirror inside of the housing. It has little "teeth" or notches that you can catch with a small flat blade screwdriver. Rotate the ring whichever way it will go, and then carefully, but with some force wiggle the mirror out. Very easy. Good luck!
Thank you for the tip! If anyone wants to know, the OBC temp sensor/probe from the flag mirrors can be transplanted directly into the aero mirrors without any modification.
