Is there any way to install a Traffic Pro in a 964?
I don't see why not - log on to Becker.de and you should be able to download the installation manual and see, obviously it's more complex as you need to connect a few additional wires but it shouldn't be imposible to do.
Keep us updated as I am also very interested.
Best regards
Emilios
Best regards
Emilios
Super Moderator
Needs More Cowbell
Needs More Cowbell
http://www.swstereo.com/
They can sell you a wiring harness adapter specific to your vehicle and headunit.
Registered User
most sat-nav systems just have an extra arial to be put on the dash or rear window area , and lots of extra wires linking the boxes , speed sensors etc.
helped fit a couple of vdo systems once ( mainly stood smoking and watching )
these were complicated as they had cd changers , tv tuners etc.
but from what i understand a 1 box head-unit type is pretty simple .
R.I.P.
Lifetime Member
Lifetime Member
Thanks guys. I have a TP in my 996 and it was virtually a plug in. Will check Becker. It's amazing, even tho the TP doesn't have a map the directions are perfect. In fact the map itself becomes a distraction, and the British gal that gives directions sounds soooo sweet!
