Clock Not Working, fuse good, now what?
The clock stopped working sometime yesterday. The set switch has no effect either. All warning lights on the face of the clock seem to be working fine.
Fuse (#11) is fine.
What are mostly likely/easy things to check next?
Fuse (#11) is fine.
Robert,
With the ignition off, I would pull the clock, and check for "always hot" 12V. Don't turn on the ignition with the clock disconnected, or you'll wind up with a locked-in airbag light.
Good luck, and please let us know what you find.
