964 Forum 1989-1994
Clutch wunderfull after slave repair.....
Old 09-20-2004, 06:09 AM
Arjan B.
Arjan B.'s Avatar
Default Clutch wunderfull after slave repair.....
Yesterday I had the oppotunity to test under hot conditions the "hanging pedal syndrome" of the clutch.....
It worked wunderfull!!!! Even sanding in line after returing to the paddock, I could hold the pedal to the floor and it returned smoothly to the top on request.
So..... If you have the hanging clutch pedal, replace the slave cylinder on the gear box, and your problem is over.......
Old 09-21-2004, 12:29 AM
Texas993
Texas993's Avatar
Thanks for the post. I have the same problem. Will have it fixed next time it is in for service.
Patrick
Old 09-21-2004, 01:02 AM
garrett376
garrett376's Avatar
Arjan,
Good finding! I had the hanging clutch pedal, did a bleed about 6 months ago, and it seemed to go away. Interestingly, I did an autocross in my cabriolet two weeks ago, and when the car was HOT after a couple runs, the hanging pedal came back! Sounds like I could use a slave replacement at some point.
It's interesting that heat makes the symptoms worse!
Old 09-21-2004, 02:52 AM
Arjan B.
Arjan B.'s Avatar
The slave cilinder is on the hottest spot under the car, so that makes it logical. I think it will clamp because of the heat. I am happy it is solved.
Nice photo Garret!!
Old 09-21-2004, 04:47 AM
Christer
Christer's Avatar
I also have a slightly hanging pedal, and will do this soon. I also want to get a 993 MC installed due to the RS brakes I now have installed. The pedal travel is slightly longer than before, and whilst not a problem at all I still don't like it...
Old 09-21-2004, 06:35 AM
ThomasC2
ThomasC2's Avatar
I changed mine a month ago and it solved my problems also. The clutch feels like new!
Old 09-21-2004, 09:00 AM
Arjan B.
Arjan B.'s Avatar
Be carefull with the connection to the steel line to the front which is connected to the rubber hose of the slave cylinder.........! Replace the hose also! Strongly recomended!
Old 09-29-2004, 11:25 PM
splattergasted
splattergasted's Avatar
Arjan, did you replace the slave yourself? I'm assuming this is not something for the faint of heart.
Old 09-30-2004, 06:31 AM
Arjan B.
Arjan B.'s Avatar
Yes, I replaced it myself, but while install the rubber hose, I broke the connection between the hose and the steel line which goes to the fron of the car. And because my car lift covers the middle tunnel of the car I couldn''t replace the line to the front , so www.lammertink-porsche.nl did this for me.
It's a diy job if you have the patience........
Quick Reply: Clutch wunderfull after slave repair.....
