993 seats in a 964
993 seats in a 964
I have an 89 964 C4 and would be keen to update the interior. I have been offered some seats, front (carbon backed) and back, and door and rear panels from a 993 turbo.
Will these fit, and the electrics work, in the 964 ?
How big a task is it to fit them ?
David
David
This question comes up A LOT. I think ( a quick search will answer the question I'm sure) that you have to change the rails to make them fit. The issue then becomes do you want to pay for the expensive rails or can you find a decent used set...
Super Guru
Whether you need new rails will depend on what seats you have - standard 993 (including 993 sport seats) will, I believe, slot right in on existing rails etc.
steering wheel spacer? Sit height
As one of thel taller guys around I need to put the seat as far rear as possible. I can hardly reach the steering wheel so does anyone know if there is an after market spacer available for the original non airbag steering wheel? I know there are a lot of other optons but I would really like to keep the original wheel.
Next problem is that I have to sit lower than offered with standard (sports) seats, especially when using a helmet. Anyone know how much lower you get in the RS seats compared to standard seat in it´s lowest position? That is with the RS seat on rails not bolted to the floor.
Thanks for any hints,
Steffo
Steffo
For Phil Raby
1 Post
I've got a set of 993 seats waiting to be installed into my 964 cab. What I found was that there is a difference in the electrical connectors between the 964 and my 993 seats. I am still trying to figure out how to go about it. My option is to move the 993 leathers to the 964 seat frame. Andy
Mike,
Its only becaiuse I want the pinstripes for my living room and the sat nav to find my way home on Sunday. (and that I have been offered some new seats of course)
See you at the weekend.
David
David
