View Poll Results: Which sway bar is more 'FIRM'?
19mm 3-way adjustable from AJ-USA
8
50.00%
21mm NON-adjustable (964.333.701.07 Carrera 2 -90 M481)
6
37.50%
Too similar to perceive a difference
2
12.50%
Voters: 16. You may not vote on this poll
Sway bar differences - adjustable vs. non-adjustable
Originally Posted by RSAErick
I suspect that a firmer front bar could bring me back to understeer characteristics, so I'd only add a 25mm adjustable front in conjunction with the bigger 22mm adjustable rear. My wish is to get rid of the prominent body roll, but I may be going about it the wrong way with sway bars considering that I'm still using the soft and progressive H&R 965 springs.
Still, it was fun to drive the car on the track for the first time without understeer. Right now, I'm pretty happy with the car.
If you wonder why a 19mm can be harder than the 22mm, it's because of the adjustments available on the bar. Not only the diameter plays a role...
BTW, there's a simple rule to change your car settings when you have adjustable sway bars:
Harder on the rear or smoother on the front will reduce the understeer
Smoother on the rear or harder on the front will reduce oversteer
Then consider that more basic rule:
hard bar on front = understeer
hard bar on rear = oversteer
Playing with that rule, I'm sure you'll find the adjustment you searching for!
PS: I use front and rear sway bars from the euro carrera RS.
NTTY
After seeking guidance from you guys, I installed the 19mm RS adjustable rear swaybar on my C4. All I can say is my car's understeer has diminshed significantly. Thanks, guys!!
964, adjustable, bar, c2, cookie, cutter, difference, function, hellwig, holes, parameters, preload, regular, sway, understanding, vs
