Where is the trans oil filler?
Going to change my trans oil before our Big Trip to Europe.
Can someone link me to a picture, or is it obvious when you get the trans undertray off? I'm sure the drain is clear, but is the filler tucked away? Will a standard trans oil bottle tube be long enough?
Is it in Adrian's book? - can't find.
Ta.
Ta.
The fill plug is on the side about 1/2 way up. You should have no problem finding it. You can get about 3/4 of the contents of a plastic bottle in. I used a hand-operated pump, and it was not nearly as big a mess.
