third brake light
third brake light
Hello I want to install a third brake light to my ´91 c4... i search the forum but can´t finde... how to connect the wire to the brake light.. wich color is the wire of the right brake light and how get i the wire to the back.. can someone help me perhaps with pictures ????
thx and greetings from hamburg
christian
christian
Christian,
This was my experience :-
http://homepage.ntlworld.com/warmfuz...brakelight.htm
with respect to the wiring, I just stuck one probe of my DVM on ground, then probed the other wires untill I found a 12v signal when the brake pedal was depressed, checked this against the other rear light cluster to make sure I hadn't wired it into the other lights, it really is simple.
Hope it's usefull.
regards
Kevin.
Hope it's usefull.
regards
Kevin.
