Dyno your car lately?
Anybody ever curious as to what your car will produce HP at the rear wheels?
If you are ever wondering go to www.dynolabs.net
They can dyno your car, friendly nice people go check it out.
I got mine done last year. Before exhaust change I only had 207rwhp (dyno converted to approx 238hp) and after it was 222rwhp (or 260 odd). I guess a good engine will do around 207-215rwhp. It also varies quite a lot with temperature and atm pressure of course.
Yes your right temp. does matter quite a bit.
I will be doing mine probably soon before and after installing a fabspeed exhaust.
A friend of mine have a 91 C2 with fabspeed, chip, K&N cone filter system
cat bypass pipe. His car dynoed at 247HP at the wheels
I had my C4 dyno'd last Fall on a dual roller: 228.5 hp and 224.0 lb ft.
The 247 rwhp reported by your friend is pretty strong. That would translate to 291 hp at the flywheel when using the standard 15% loss factor. What sort of Fabspeed exhaust and chip are we talking about?
Sorry if I seem skeptical but that's a huge leap over stock due to a few bolt ons. Does your friend have 0-60 times? He should be under five seconds easily with that type of hp.
I had mine dyno'd last November. Results were 219.7 HP at the wheels, and 196.6 lb-ft of torque. I was quite happy with the results, especially for an 11 year old car that is (as far as I know) 100% stock, except for the wheels.
Here's the url for the data.
http://www.castlerockacres.com/964Dyno.htm
Ron
91 C2 Cabriolet
85.5 944 NA
Ron
91 C2 Cabriolet
85.5 944 NA
Christer, since the last dyno run, I have had a later plastic inlet manifold and single 'enlarged' throttle body fitted, this should compliment some of the previous upgrades and give some more power.....in theory !
Christer, the engine had top end overhaul (really for cosmetics, slight oil seepage, but good power). In addition to this:
RS LWF & Clutch
De-cat
Cup pipe
Injector overhaul
Machine Heads (to raise compression ratio)
New Valve springs and Titanium retainers
Sport Cams
Cup Airbox
K & N filter
Re-chip
Plastic inlet manifold and large throttle body
I think thats it for the engine
RS LWF & Clutch
De-cat
Cup pipe
Injector overhaul
Sport Cams
Cup Airbox
K & N filter
Re-chip
That IS a good list, Gavin. Would it possible to for you to scan the dyno plots and then post them? Air/Fuel mix numbers would also be good to include.
