New Fvd 964/965 Pss-9 In Stock!!!!
Arjan,
take a look behind your wheels and take a look at the spring (coil) you will see it's placed around (over) the shock absorber (damper) hence coil over shock. Hope this helps.
Originally posted by Laurence Gibbs
In answer to Julian, if these pss-9 units are the dual coil type then you will get a car that handles far better on the road and will still be a good car on track. However it's likely they wont match the track manners of the standard Euro RS( but they'll get close). The dual coils allow for a small softer spring to take up the bumps and ruts on the road(compliance) while still having the main spring to do the hard work with. In a track car the small spring becomes a little redundant as the last thing you need is too much compliance. The other thing to check is that these units are suitable to mount to your uniball top mounts! if not you will have to go back to the standard rubber top mount and you will be "softening" the suspension some more. Overall I know the pss-9 has had some very good reviews it's a case of you pays yer money and takes a choice!
