Ebay CS injectors for 964
I would ask about their compatibility with the injector constants burned into the motronic chip. The answer won't likely be informative.
There are a number of injector refurb shops around if you're seeing poor spray patterns or leaks. Upgrading to a better low-rpm atomizing design will require some non-trivial ecu software tweaks.
Sounds like they put a disk with four holes in front of the pintle. Pintle and multi hole injectors are completely different designs. You can’t turn one into the other with internal parts.
Just get some used (4) hole injectors and clean them up with a 9v battery and some carb cleaner. I think the 19lbs/hr (I think it was the 19lbs/hr I put in my car, it was a few years ago now) out of an older Volvo one are sized right for a 964. I put some in mine and it runs great.
I would strongly discourage random replacements. Latency and voltage corrections are in the chip and will not be the same between different injector models, in addition to flow values. I’m not sure what the risk is on burning the injector drivers. Not worth tossing something random in and experimenting though.
http://users.erols.com/srweiss/tableifc.htm
Match up the flow rates, connector, impedance, clean them out and off you go.
I use in my 964 Ford 0-280-155-700 = 18.25 lbs/hr , 191.8 cc/min , 138 grams/min , 3 bar , top feed , high resistance injectors.
They are 4 hole new desing injectors. Got it from ebay as used , but original, and in ebay are lot of chineses injectors with same product number
Good start, very flexible ride, lot of butt dyn power
More info about injectors here:
https://rennlist.com/forums/964-foru...injectors.html
I dug through my emails and found that I used 0-280-155-746 injectors in mine. 19lbs/hr, 199.7cc/min, 143 grams/min, 3 bar, top feed, high resistance injectors. They are out of a Volvo and are the EV6 style with 4 holes. They are supposed to have a finer spray pattern vs the EV1 injectors for a better burn.
Stock is 0-280-150-731 = 18.45 lbs/hr , 193.9 cc/min , 139.5 grams/min , 3 bars , top feed , high resistance
Technical Guru
Looking at the picture you could see the bosch part nbr 0280 150 943 .
So they are original , so a little strange the convertion from pintle type to 4 hole is not possible as per previous reply and noboby did have a go .
