Could someone please get me a part#??
Hey guys, need some quick help. I cannot find the part# for the brake line (hard line) that connects directly to the rear calipers on each side. I need the hard line for a narrow body car. I cannot find it in the PET either for some reason unless I keep missing it. Any help would greatly be appreciated! This is for my widebody to narrow body trailing arm conversion. Thanks!!
Mr. Wolfe
Mr. Wolfe
Should be on page 604-10. #11 964-355-189-01 (left), #12 964-355-190-02 (right). The lines that connect to the junction that runs forward, and also connect to each side hose. Appears that those lines are identical for the narrow or turbo/look models, and the latter have an additional line extension.
Hope that helps.
Hope that helps.
the part number for the hard line to the caliper is 964 355 191 01 and you need two of them....same for each side....
the 964 355 189 01 and 964 355 190 02 is the hard line on the body in the rear that the flex line would attach to !!!
Hope that helps.
Hope that helps.
Mr. Wolfe
