Picked up a '90 C4 w/51K miles
#61
I helped my friend Pino with a late build 89 a number of years back and it still had the original dual mass. They were known to have issues as you know. The luk I have will bolt right up.
#62
Motor dropped. Will replace fuel lines, front rusted tin and a few other while your there stuff like welding planetary gear pins in the center diff along with clutch and flywheel.
#63
Nice, I replaced all the fuel lines in the engine when I had my engine rebuilt. But I forgot to look at the 3 hard lines from the fuel pump. *facepalm*
#64
I believe there are 5 lines on top snaking around the intake manifolds. The long one with soft line ends that runs from fuel pump to right before the fuel filter makes it six lines total.
#65
Yep, I did all 5 of those lines. I did Griffith’s for the two under the manifold since they’re steel braided. Kinda wish they did all of them but oh well. I just went with OEM for the rest.
#68
I would consider changing the injector seals and check the seals on the power steering pump and replace the power steering belt while in there. I just dropped a 91 and the seals were plastic. They just crumbled. Also as you probably know the primary fuel line is different for some MY's. Not a bad time to do the timing chain cover seals as well. The rubber grommets shrink over time and don't hold the seal tight enough and they begin to leak. If they are original it is worth doing.
I don't recognize the shop who did you end up using?
#69
#70
#71
More work. Timing chain covers leaking. Engine tins off. My cold leak down and compression numbers are good as well!
#72
How bad were the leaks? looks like the sound deadening pillows on the heat shields are gone as is with every car I have worked on. If they get too saturated the plastic will absorb the oil and although thoroughly cleaned when heated the oil will leach out and continue to make a mess on the floor after spirited driving. I personally don't reinstall them but found using a purple degreaser in an ultrasonic cleaner for many cleanings helps. I am assuming you are changing all the seals at this point and might as well change the O rings in the cam tower bridges. Good time to check that the oil squirters for the upper rockers aren't clogged. Also I don't like the red O rings used on the 964's in the cam tower bridge. They start off round and very quickly will flatten out and leak again. I use the black ones from the 993 they seem to hold up better.
#73
heliolps2 (08-29-2021)
